phone not switching on after switching off
horizon1
hi,
i brought  xperia j 6 monts ago and now iam facing problem with the phone.the phone is good but when i switched it off it doesnot switches on and after long time it switches on but the touch doesn't work.pls give a solution
4 REPLIES 4
Connect your phone to a wall charger > press and hold power & volume up for 5 seconds > let it charge for 1hour > after 1 hour try to repair it with SUS or PCC
Don't forget to give Kudos
shihstouch
Enthusiast
Have you tried this?
There are a few things you should try first when you experience problems with your device:
  • Restart
    Restart your phone to turn off all running applications and to remove memory blocks. Remove and reinsert the battery and the SIM card. Then restart your phone.
  • Update
    Update your phone to ensure that you have optimal performance and the latest enhancements. Read more about how to update and find latest software version.
  • Reset
    Reset your phone to its original settings to remove memory blocks: Settings > Backup & reset > Factory data reset > Reset phone Don't forget to back up any important data saved on your phone!
Xperia_J_user
I also had the same problem with my Sony Xperia J.
When I tried to charge battery, red light was blinking..not charging after 1 hrs also.
After trying for many times....finally after 4-5 tries mobile started....
Tags (1)
