Xperia U Phone locked. I turn on the phone and you will see a keyboard with key emergency calls only. How can I unlock it?
The tested sim in another phone works.
thanks
It could be a phone lock.Download sony update service and repair:
I downloaded the software, but my model Xperia U is not present
are you sure U isn't there?wich windows you are using?
windows 8.1
Run the program in compatibility mode
Windows 7 32 bit don't use 64bit as you will get the same issue
@Thommo wrote:Run the program in compatibility mode
this is your solution
Thanks for the advice. I upgraded and unlocked with PC Companion.
Great.
