Phone doesn't respond at all
myxomatosis
I was doing software update, my computer asked me to connect a phone in a flashing mode (with held VOLUME DOWN button), Windows started to install new devices but it seems that failed. After this I tried to turn on my phone but it doesn't respond, neither with a combo VOLUME UP+POWER. Phone is not charging at all. Computer says it's "unknown device" - without pressing any button and with pressing VOLUME DOWN button. Is there any help for me?
6 REPLIES 6
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
myxomatosis
Nothing happens, because for computer it's "an unknown device". I checked on two.
Thommo
Genius
When performing the system repair as detailed above do you when asked with the phone switched of hold volume down then connect your USB cable - This should begin the Flashing/repair process
Thommo
Genius
If you need the Flashmode drivers then you can find them here
myxomatosis
Nothing at all. I've installed flashmode drivers, I've checked this on two computers and still nothing. "Unknown Device" and Companion doesn't even react. Looks like the system crashed completely or something.
kodekobra
I have exactly the same problem. None of the steps you recommended worked. Please advise!
