Phone calendar
Audicar
Phone calendar
When I go to calendar-menu-My calendars I read default account is phone calendar and its synced and visible.
My question is with what is it synced. For example birthdays from contacts are not visible. When I use google calendar birthdays  are visible.
Also on the native calendar widget birthdays are not visible.
Another question: Where has data-use widget gone in ICS?
CPB
5 REPLIES 5
Markus1
Leader
The Google calendar is synced with Google, the Facebook calendar is synced with Facebook, Hotmail calendar is synced with Hotmail etc... I think you understand. Slightly_smiling_Face
The calendar widget will not show full day events. Birthdays for example will not show here.
There's unfortunately no data counter widget in this software version. You could most likely get one from Google Play though.
If you go to Settings > Data usage, you'll find good info on the data transfers.
Audicar
I did put a 3 day vacation in the calendar and all 3 days are showing in the calendar widget. I.m.o these are 3 full day events.
CPB
Markus1
Leader
Did you tick the "All day event" box or did you just create a new event from 00:00 to 23:59 three days later?
Did you enter this in the phone calendar or Google calendar?
nguido
Marcus,
ALL DAY events are not showed. 00:00 to 23:59 are showed in widged. This happens if ICS is running on my XPERIA S. With GB, both events was displayed.
Is this a bug solved on next update ?
Regards
Markus1
Leader
It's not considered a bug but it could possible be changed anyway. Not sure if it will though as I do not have information on planned changes in coming software updates.
