Hi please help me to the solution on it without loosing my data...
The phone is not starting again after updating to loliipop
I am sorry but you may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
