pc companion not working....
meamit123
My laptop in connected to internet connection and m able to browse websites and download all stuff still sony pc companion is saying connect your computer to the internet and try again Slightly_frowning_Face
10 REPLIES 10
sajibtech
Uninstall you previous PCC and downloa it http://www.sonymobile.com/gb/tools/pc-companion/
Now if you using Win7 then right click on .exe then choose "run as administrator" after installation connect your phone Winking_Face
meamit123
i m using the same version of pcc dat u recommended...
sajibtech
Ok then follow next process that is, unistall and restrart you system and click on .exe to select "run as administrator" also should check firewall for its blocked or not...:smileywink:
meamit123
tried but nt worked!
shud i hv to do something wid pcc proxy settings???
sajibtech
You can try this :
If this not work then you can go for next optoion" automatically detect"
meamit123
txx bt i tried all d options didn't work,,,, :smileysad:so nw m downloading SUS...
sajibtech
Ok, but i think your firwall block PCC, try to check again...:smileyconfused:
meamit123
ok will try 2mrw...
update is running in sus... Dizzy_Face
sajibtech
Congtrats....:smileylaugh:
