P1i Alwas Restarts
P1i Alwas Restarts
My Sony Ericsson P1i Always restarts Saying ” The phone has restarted  in order to improve it’s performance”. And i can’t turn it on. But Via  the flight mode it can turn on but without sim. I tried SEUS but didn’t  work for the problem. Some times Phone works for day or 2 in those times  when getting calls calls are sucked that means i can't hear what the  caller say and he can't hear me ether.
I asked this before but no one helped. Please Answer this time.
Please say a way to Repair my Phone By my self.
Thanks
6 REPLIES 6
Dr_Chris
First try a Master reset and if this doesn't solve the problem, you can elect for the "repair phone" option via PC suite.Just remember to back up your data in either case.
I tried master reset but no use.
Dr_Chris
Try SEUS again, followed by the "repair phone" via PC suite option, if SEUS fails to solve the problem.Contact SE if none of these work.
I didn't Tried Repair option. Is it in the new verstion?
I tried seus so many times but no use.
I contacted Help Senter But no use. They didn't Helped much
Please Help
Dr_Chris
Open PC suite on your computer and at the top left click on "Help" and select "phone repair".Connect your phone via USB and follow the instructions, remembering to back up all your data.It's also probably a good idea to look for a newer version of PC suite (see "Search for PC suite updates", also under the Help tab ), if there is one.Failing this, try contacting SE again.
There is no repair option in PC suit. i have new version.
