os using too much data
tangonz
Just after a bit.of advice, my z1 has used half a gb of data in under 3 weeks is there anything I can do to limit the amount of data it uses? Also the screen turns off while I'm making a call it doesnt turn back on until the other person has hung up, so if I get there msg bank the only way I can end the call is if I turn the phone off, it has started doing it when receiving calls also so I can't answer it. A message pops up at least twice a day saying the " walkman has stopped responding" even tho it still works, sometimes when i let the battery completely die it wont charge until I press the reset button, not impressed at all especially for how much the phone cost, definitely should have stayed with apple.
Tags (1)
6 REPLIES 6
profile.country.RO.title
_alexdon_
You have that problem where the android os uses data plan?Have you considered a software repair?
alexdon
tangonz
Il consider anything to fix the problems, how do repair the software?
_alexdon_
Download and follow the steps provided.Backup your data before,as it will erase phone memory.
alexdon
tangonz
And yes its the android os that has used half a gb out of my monthly 2.5 gb plan.
tangonz
Thanks, will give it a try
_alexdon_
This issue has been seen before,although no one has found a fix.So I suggest a software repair,it might help.
alexdon
