is there any way to customize the notification light pulsing? In a dark room it easily distracts for example when awoken from sleep.
It would be nice to have a 'night mode' option, that switches pulsation at certain times.
Or maybe a profiles settings to have meeting, night, etc modes.
this app may help to you https://play.google.com/store/apps/details?id=com.rageconsulting.android.lightflowlite if this helps give me kudos thank you
Thanks @zakirox.
Been trying this, but I don't think I have it yet.
I enabled sleep mode but it does not switch off the battery charging light when it gets to sleep mode.
It also seems to be causing a dobule notification for example when I receive a Hangout message.
And sometimes the service doesn't run at all.
Nevertheless, will keep experimenting, in the hope that I'll get the correct settings. Sounds promising.
Note that it will take over control of your notifications and you will therefore only get notifications for categories that the app allows.
The app requires you to add "accessibility" for "light flow lite" - as this allows better control of the notifications. We do not capture your data, this is just a standard message shown when adding accessibility. If you check out the app permissions the app does not require internet access, so you can rest assured that your data is safe.
you can try this app to enable/disable the LED notification light from the homescreen. https://play.google.com/store/apps/details?id=com.motorola.ledwidget
