Manual says:
"Notification Light
The notification light informs you about battery status and some other events. For example, a flashing white light means there is a new message or a missed call. The notification light is enabled by default but can be disabled manually."
The problem is, that notification light setting is enabled, but only battery notification light is working. I tried custom app -s ( LedBlinker, LightFlow) and they also won't enable any missing call/message light? The light himself is working fine, as when testing it with Led Tester, all colors are OK.
How to fix it?
@Viridis wrote:
Uninstall all the apps messing with your led configuration and turning the notification setting on and off would be my first move.
Already did that, removed all custom apps > restart > disabled notification > restart > enabled notification > restart = same problem. And strange, that LightFlow works fine with others phones running 6.0.1 and 5.1.1.
Edit: Turned out, that ExDialer function "Replace Missed Call Notification" was the reason. I will discuss with eExDialer developer about this issue.
