Not Charging .
Not Charging .
My Xperai Neo V is not charging , there is a red light and a zigzag inside the battery bar that notifies that its chraging ..but instead of charging it drains the battery power .
3 REPLIES 3
i have same problem but in my Xperia RAY!
Nessa
Are you using an original battery and charger? Are you trying to charge it through the USB cable or directly through a wall socket?
Yes i am using original battery and charger, the one comes from the mobile when i bought it. I am charing using the two method(USB and WALL SOCKET).
