When I talk with someone, sometimes the speaker is presented a noise like the wind. I hear a noise, and the person on the other end hears it too. The noise is presented not always. May appear on the outside or inside. The phone does not fall, not in the water, I bought it 3 days ago.
Should I carry my phone in service, or is it a problem with the firmware? Xperia Z
Maybe the problem is the sim card the old model, which I cut myself, made a micro sim, but with SGS3 it worked well...
Go to settings then call settings and turn on noise suppression
Noise, anyway, on or off, it does not matter ... I have and the one to whom I call
Well now i read that you have cut your sim yourself please get a new micro sim, the sims that are cut usually have problems
nothing to do with the sim - I think you have a hardware problem and need to return your device to service center
as a last ditch fix - use PCC and do an update repair - remove/uninstall all apps you have installed - remove the antivirus software - do not install any apps after and see if the problem is still there
also do a backup of contacts etc using PCC - do not restore until you have tested the device
also remove your SD card if fitted
let us know how you get on
some people had this problem when they cut their sims....it solved when they got a new one....even uliwooly has pointed it out in many threads
the sim card is not involved in any media imformation transfer - it is simply the key for getting on the carrier network
blaming the SIM for this problem would be like blaming a car key for a for a radiator leak - no connection whatsoever
I'll eat my phone if I'm wrong
Its not media transfer its disturbance in call that he's having when he talks to someone
This disturbance can be the fault of the sim
Will you atleast let him try putting a new sim or you just want to fight with me
by media I mean everything including voice transport through the phone - it doesn't go near the SIM
SIM is short for Subscriber Identity Module, a "smart" card securely storing subscriber-related data, such as phone numbers, service details, and memory for storing messages (depending on the phone); also called SIM card. GSM technology uses a SIM to authenticate the phone on the network.
