No signal
Vanek
No signal
Hello! Bought xperia V week ago, phone is new. It begin lost signal from bad 3g to very good edge, but then it lost it absolutely to 0. Says that only emergency calls available. Restart helps some time.  Is that known problem? Any solution?
11 REPLIES 11
lon
Same problem here Slightly_frowning_Face i will always turn off and turn on my phone (xperia v) to back in normal signal
Alexander1
Sounds strange!
Have you updated your phones to the latest software using PC Companion?
Try to change network mode from LTE/WCDMA/GSM to WCDMA/GSM to see if you experience any difference. Go to settings > more > mobile network > network mode.
If the behavior is the same I suggest that you try with another SIM card in your phone.
Viktor1983
Hi everybody!!!! I Can say that this problem is a flaw Sony firmware Android 4.1.2 for Sony Xperia V.Данную problem is practically impossible to eliminate: reflashing Sony PC Companion or Update Service helps temporarily,as well as rebooting the аппарата.Мне sometimes makes you this way: in the calls menu, dial *#*#4636#*#* opens the tools menu (hereinafter strictly as I point) choose in the phone information lowering turning find below the set the preferred network type select the LTE/CSM/WCDMA and click the Home button.:smileysmileywink:
Yasi
The same problem is here Slightly_frowning_Face I lose my signal antenna randomly.. rebooting sometimes help but it is very annoying because  I always missing important calls...  is there any ceaseless solution?
Tags (1)
Yasi
Problem did not solve yet.. any one can help?
Vanek
Latest software, network change didn't help. Sim card is new.
YuriyV1
Jumping in with the same issue - Xperia V is 1 week old, however, several times a day it loses a network. Note that signal level on a screen shows perfect connection and  I can make a calls... but no one can reach me. Scrap. And two more problems: charging indicatior shows everything even mid-summer temperature on Mars, but not an actual charge level (and besides of it, % of charge displayed jumps up and down randomply even if  phone has all services off and SIM card removed) and people I'm calling always hear me with gaps and rumbling
YuriyV1
Bump. No ideas? Maybe that's a manufacturers' flaw? If yes, could you please send me an official e-mail with confirmation, so I'll be able to return my phone back to the shop and get a refund?
Sanj
You may try to reflash teh software with PC companion or SUS or take iot service centre that might help.
