No Contacts appearing
kurdz
Hi everyone,
I'm kurdz. It seems that all my contacts would not show in the contacts of my XPERIA TX. It says that I donot have any contacts but in the messenger some of my contacts are appearing. I tried to add contacts but it does not appear on the CONTACTS tab. Is there anything I can do to troubleshoot this? thanks a lot!
4 REPLIES 4
Open the phonebook > menu > filter
kurdz
I tried that from another forum but it doesn't work for the TX. I don't really know what happened.
on your PC access your gmail > contacs > are your contacts there?
Sam
Legend
Legend
If they don’t show in the contacts section but do show in messaging then it will be a filter as Uliwooly said. Once you are in the filter settings make sure the top two options under Filter contacts are not ticked and that all options under the Contacts to Display are ticked.
What are your thoughts about this forum? Let us know by doing this short survey.
