Have you tried a restart?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
If the Software Repair hasn't worked then contact your local Sony Mobile Customer Care team - their contact details are in my signature.
