Networks romaing
Moathmalek85
Networks romaing
Dear Sir,
im using sony Z3 Dual D6633 , i set the network to manual selection, during that time the screen showed the name of (provider) network i selected or " emergency service only" is it possible that the phone it self change to another network without my knowledge .
Many thanks
Moath
17 REPLIES 17
@Moathmalek85
It shouldn't but you can try this
Settings > more > Mobile networks
you can chekc Data roaming and also your carrier
Settings > more > internet settings > select your network > accept
Moathmalek85
@Sony so it's not possible at all
Moathmalek85
@uliwooly
Moathmalek85
Thank you
but I was travelling to Palestine and I changed the network manually into Jawwal Palestine. When I came back to Jordan I have been requested by Zain Jordan a huge amount of money claiming that I was using Israeli network which I didn't. How could this happen while the network was chosen manually
& How can I prove against zains claim
Thanks
@Moathmalek85
@alexdon @Thommo any suggestions?
Thommo
Genius
The problem I see here often happens here in the UK in that a network signal strength can be stronger coming from France so instead of using a UK network it will jump to a French network so I can only assume that because you have Roaming enabled then the signal strength coming from Israel was stronger than the one where you were - If this is the case then you could argue that it's the networks fault because there strength was weaker (You'd need to check your telecommunication's law on this) but also at the same time you are the owner and it is your responsibility to check
Moathmalek85
I always check only jawwal and if there is no signal it's well be emergency call only
Thommo
Genius
I'm sorry to say but I don't see how this is a Sony issue as it appears to be more of a network issue and not something we can help with nor can Sony
Moathmalek85
I know it's not from Sony and it's from zain
But I want to prove that Zain so as not to pay large sums of money
How do I so
Is there a way to learn and network access on certain؟؟
