Network problem on sony xperia tipo dual
logesh
Any incoming call to my phone (model sony xperia tipo dual) i'm unable to view the caller's name instead an error msg stating unfortunately unable to process appears on the screen. The minute this error msg appears there is no network signal to both of my sim. The network signal appears after few mins only. Due to this i'm unable to attend any calls. Has anybody faced such an issue. Wat can be done to rectify the same. Thanks in advance
Sam
Legend
Legend
You may want to try running an update/repair:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
