Hello...My Dear...My Sony Ericsson W350a has No Network Coverage?
Im using GSM 900 MHz...How can I reslove that problems? Please help me...Thanks
If you cannot get network coverage anywhere you go, switch the phone off, remove the SIM card, clean the contacts, replace the SIM card and restart your phone.Let me know if that helps.
Dear Sir, Thank you so much for your reply.
I switch the phone power off and remove SIM . After that I deleted all contacts and restart again.
But I can't get Network. Im searching Network by Menual .But my phone can't access any network.
Im using form Myanmar ...our country code is MM 900 and 4140.
Dear Sir , do u have other idea?
If you have help me please.
Thanks anyway.
Did you have network coverage before with the W350a, or was it like this from the start? Have you tried using a different SIM card from the same or a different mobile operator?
The W350a doesn't support GSM 900 frequency, only 850/1800/1900. You would need to find a service provider that uses GSM 1800 frequency for this phone to work - it was made for the Americas.
