my xperia Z's sensor doesn't work
khocho
please, somebody tell me what to do, i've bought my phone from ebay, not even a month as i use it, i've not dropped it, even in water. and suddenly it's sensor stopped working. i've tried restart, with turn off button and volume up button, when it restarted, sensor worked for 2 seconds, then nothing. Tell me what to do please? :X :X
16 REPLIES 16
@khocho
Did that worked?
khocho
phone just started working, don't know how, but it started working. but now it as another problem 😕 it turns off by itself. i will set it up and will let you know if it'll work. aand thank you for so much attention
khocho
how's your phonee?
@khocho
could you elaborate on your quesiton?
khocho
okay, first of all, when i try to write my IMEI it writes that IMEI isn't valid, but i correctly wrote it!!  then, when i push repair button, it says that online repair isn't available in my country. but the main problem of my xperia is that, sometimes it stops working and turns off, and when i turn it on (with turn off button and valume uo button) sometimes it turns on, but imediately turns off again, and when i try to turn it on again and again, there's written that androrid is starting.  but this process ended only once!! and the  i reseted my phone, and the next day, it turned off again. s i don't know what to do, can u help me? do you think that this phone isn't original? as IMEI code isn't found 😕 ? but it was written brand new original phoone... don't know what to do. android is starting
@khocho
what if you call your Local support ?
berste
Hi, thats exactly how my problems started aswell with my Xperia Z. It started to turn of, when i turned it on it optimized apps. Then crasched etc. Then after a day or two it only worked with the charger plugged in, but still crashed if you used it.
You can read my thread, there are some advice in there, that sadly didnt work for me. But might work for you.
Please if you ever find a solution please reply so I can fix mine aswell.
