Try performing a system repair using PC Companion as this will often fix issues
I have tried that but it hasn't worked at all, it just stays in the loading screen, also my phone won't connect to my PC if my phone won't turn on, thank you anyway for your help
As I said your phone must be switched off to perform a system repair so it sounds like you haven't performed a system repair
