my sony xperia s won't turn on
HeartCharly
well i havnt been using my Sony Xperia S for a few weeks because, it kept crashing, turning itself on & off. one day i woke up it was fine but i noticed the battery was draining quickly then it turned itself off. i put it on charge over night, i woke up in the night & checked my phone it turned on but it said it was on 14% battery when it had been on charge. i left it on charge for the rest of the night when i woke up it only got to 22% so i was just using my phone while it was on charge then i noticed the battery was draining while it was on charge. i decided to let the battery drain then someone mentioned a super reset thing on it so i looked it up online. it said the reset you hold the off button and the volume down button till the phone vibrates once, so i did it. then it said if that didn't woke do the same till it vibrates 3 times i did that and nothing happened so i left my fone in the draw for a couple of weeks now it isn't turning on at all. do you think you know what my problem is ??
connect your phone to a wall charger > press and hold power & volume up for 8 seconds > let your phone charging for 1 hour > after 1 hour > press and hold power & volume up until it vibrates
Don't forget to give Kudos
