One Day I was putting my mobile on a table with water on it(i didnt notice the water) somehow the mobile sucked the water inside it. there was water inside the screen but it was working normally.i though of opening the phone and wipe the screen from the inside. I did that but when i try turning it on it gives me a small vibrate but nothing shows on the screen. i tried charging it for a while after 30 secs when i connect the charger a green light appears but nothing more. Any idea how to fix that please?
It would appear the water has caused a short circuit and would need to be looked at - Contact Sony to find your nearest service centre http://www.sonymobile.com/global-en/support/contact-us/
But the mobile was working so normal even when water was inside it...
If your phone was on and working then certain points or pins aren't been used - Turning off then on will of applied power to other areas causing the short circuit - Water trapped under heatshields is the worst offender and is more often than not the main reason - These areas are places owners seem to never check simply because they are unaware of it
