Multiple problems Neo V
I bought a Sony Ericsson Xperia Neo V a couple of days ago. A few hours after playing around with it I noticed some problems. The problems I had were:
1) the Wi-Fi stops working and can not be turned back on. I have seen this in other blogs. Mine now works perfectly. (All I did was format my SD card and factory reset the phone).
2)SD card  issues. Phone suddenly stops reading SD card and tells me its no longer there. Also solved after SD formated for some reason.
3) Screen goes black but can see the light inbetween the keys below screen go on and off when I press the unlock key on the side (as if I am unlocking it and locking it again.)
pls help me out before I damage the phone.... Have opened it up to get the battery out so may times Dizzy_Face doesnt seem to get unstuck any other way. Turn it off to get it back up n running again.
I wanted to get all the problems I am having in 1 blog.
22 REPLIES 22
slimshaddy
Hero
so did you repaired ? you have to click on install anyway when it says " you have the latest version"
All it needed was an update PCC! All works fine!
dimitrios
Hi Experts,
I have very similar problem to number 3 in the discussed topic
After almost two years having this phone working properly, I decided to move to clean version of ICS (without any local carrier garbage). I used official update guide with flash tool and rooted my phone. No boot unlocking performed. Everything was working properly for about month or two, but after that some lags with screen started.
Many times the phone’s display remains off after unlocking. I feel that phone is working, there is vibrating while unlocking and sounds of clicks and there is light under navigating buttons. So I’m locking phone again with power button and try to unlock again. That might succeed after one or two attempts like this, and might take longer. After the display turns on successfully, phone is acting as usual.
I tried “Update Service” but it tells me that I have latest software. Flashing back to GB or reflash it again to ICS does not help.
For now I’m leaving phones display active while charging and that helps me to have it available.
I doubt that it is worth to give to service repairs because it will cost too much. My question: is it a LCD that makes the problem? I’m thinking just by a new LCD and replace it, will it help?
Any help will be appritiated
Thank you
