I bought a Sony Ericsson Xperia Neo V a couple of days ago. A few hours after playing around with it I noticed some problems. The problems I had were:
1) the Wi-Fi stops working and can not be turned back on. I have seen this in other blogs. Mine now works perfectly. (All I did was format my SD card and factory reset the phone).
2)SD card issues. Phone suddenly stops reading SD card and tells me its no longer there. Also solved after SD formated for some reason.
3) Screen goes black but can see the light inbetween the keys below screen go on and off when I press the unlock key on the side (as if I am unlocking it and locking it again.)
pls help me out before I damage the phone.... Have opened it up to get the battery out so may times
doesnt seem to get unstuck any other way. Turn it off to get it back up n running again.
I wanted to get all the problems I am having in 1 blog.
Not having much experience with android phones I would rather avoid doiing something like that myself.
+ I havent changed anything on the phone. Got it from sony with ICS preinstalled so I find it very unlikely for them to have done something wrong (not installed properly). Update center sais all is up to date.
well tell me what apps are you using ??? and check how much free ram are you getting right now ?
lol... just happened to me again. Was downloading some game. left it to download and screen locked just like it normaly does after a while. Then unlocked it to see progres, but by mistake locked it again. Barely had time to see the screen turn on. After that tried to unlock it again and no responce. black screen! I am using simple apps like advanced task killer, IMDB app, barcode AVG antivirus... dont have many games and any other app that came with the phone that can not be removed. I have about 150 Ram free.
okay so the problem maybe becoz of task killer n Avg .. i advise u to unisntal both and thn see if the problem persists
Mobile is factory reset and has same problem. When screen stops working apart from the lighs I checked and I get some sound from the speakers when I press the volume buttons. Its as if the display stops working. Everythine else works. Phone also acts slow now.
omg is a pain...
you shoud repair ur phone using PCC or SUS ..dont worry it will come back to normal n will work fine ..
if u r not confident then you should visit service center n ask them to repair ur phone
Also gets hot...maybe it work slower as its temperature goes up?
Can you guide me with PCC or SUS?
it should not slow down or anything hmm
connect ur phone to lappy or pc via usb and start pc companion
click on check software update and it will ask you to repair also ... and thn follow the intrustions
Here's the link for both these programs:
PC Companion:
Update Service:
I hope it helps.
What do you think about this forum? Let us know by doing this short survey
Ahhh yes! Updates! THnx a bunch! Umm... I thought I could update via Wi-Fi off phone. System Update or whatever that is called in app screens. I used that and it said I was using latest version. Well I hope this works.
+Forum is great! Fast responce every time :smileygrin:! Thnx
