Hey guyz, today morn i used betterbatterystats to see wat has been consumin my battery n i saw tht deep sleep and moderate signal had the maximum bar and percentages... wat is moderate signal? n m gettin a good network signal on 2G and my 2G is always active evn at night...my phone doesnt go on stand by mode..can any1 tell me the how to get rid of this moderate signal thing? and has 2G been consumin my battery all night??
battery apps are really bad for you as this apps will drain battery and well check the permisions it require.
if you want to see all that go to
settings > battery
charge your phone 100% > use it as you normally do > once it reaches 10% take screenshots (screenshots volume down & power for 2 seconds)
the whole list
the graph
tap on the top 4 items and post the info here
most likely you are syncing with fb or google or twitter or other apps and that's draining your battery
