Mobile restarting automatically
hi
i am using xperia x10 mini,my mobile is gettting restart automatically and some time it get hang(no display and no audio,but if called to that number means the call is going but no audio and no display in my mobile)..
17 REPLIES 17
Nabeel
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
anyone reply me
Hello Nabeel,
I am also facing d same problem, and m trying ur suggestion, but the problem that am facing now is that, while i am giving repair instruction, my experia X10 mini pro automatically restarts due to which repairing gets disconnected.
help me out with this problem.
Nabeel
Use SUS
i successfully did the repair work, yet facing the same problem, i.e it automatically restarts, but lesser number of times than before. any solution for this?
Nabeel
Have you installed apps on your mobile ?
gwhispererz
Hi Sushmita20, see if Factory Reset helps .... Settings>Privacy>Factory data reset.
This will erase phone data completely.
yes, i have installed apps on my mobile.
will the factory reset also delete backup also ?
just to be safe
