You can always try to boot the phone into safe mode to exclude problems related to third party apps:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
To be able to send and receive MMS, you need correct MMS-settings via Settings > More... > Mobile networks > Access Point Names. I suggest that you double check these settings with your network provider and also make sure that this function is enabled for your subscription.
Otherwise, I suggest that you try another SIM-card. Note that if you try another SIM-card from another operator, you need their MMS-settings.
I have the same problem also, same as you on Friday, have you fixed it yet, noone knows whats wrong woth mine
Hi maxe, Have you tried my suggestions above? If not, I suggest that you try them first.
i have tried everything except the sim card which ill try tommorrow.
Thanks for the help.
still no joy in getting this fixed:smileysad:
