I have recently been experiencing missed calls and can't seem to figure out why. Whenever somebody calls, it will go straight to voicemail and I do not receive any notification that they called. It doesn't happen all the time but it's still a problem as I need to receive calls for work. I find it tends to happen when the phone is left alone for awhile, particularly at night. But then again there are times when it is left alone and I still get some calls. Like it only works when it wants to. I checked the settings for stamina mode and added calls and tests to exceptions but I don't think it made a difference.
Hi @jean92,
As uliwooly mentioned this could be SIM/network related. I suggest that you try to change your phone's network mode to WCDMA/GSM and see if that would make a difference in this case.
You can change the network mode by going to Settings > More > Mobile networks > Network mode.
If it is already set to this network mode then try setting it to GSM only instead.
