Miro Xperia heated to make a call, it is normal????
VictorRuiz82
When I make a call about 5 min the computer is starting to warm up in the part where this SD slot
2 REPLIES 2
VaibhavAds
Check Phone temperature using Android System Info or Android Assistant.
Phone temperature after a call shouldn't be more than 40 Deg. Cels. If it is, then there's some problem.
Do you've at least -81 dBm 16 asu Signal strength? Go to Settings>About Phone>Status>Signal Strength.
How do you hold your phone? Grab only at corners/edges, don't use palm to hold it, use fingers to grab edges.
Let me know if issue gets fixed.
Don't forget to mark Correct Answers & Helpful Answers
Sam
Legend
Legend
All handsets will generate a certain level of heat when in use, this is normal.
