Miracast Issues
geckleopard
Miracast Issues
Hi has anyone had any issues connectin. To miracast displays my phone connects but I get no audio and the frame rate or performance makes it unwatchable. About 1 frame per second. Has anyone tested this and seen it work?
Cheers,
Ian
Tags (3)
4 REPLIES 4
Rickard
Sorry to hear you're having issues with Miracast.
I just tested it here with a Sony Bravia TV but it works fine for me. What device are you trying it with? Have you tried updating the firmware?
geckleopard
I'm on firmware 17.1.A.2.55 . Z2. I was using it with a Samsung BDF6500 bluray player which is a miracast certified device and I have tested that with other handsets and they all work - HTC one, S3, Nexus 5. Will check the firmware of the Bluray player and make sure it is up to date.
Thanks for the quick response.
Ian
Rickard
That's the same version that i was testing here but i'm unable to test with a BDF6500. Please let me know in case updating it doesn't help and if possible, also try your Z2 with another device to see if it's a general problem with Miracast in your unit or something that happens with this specific device.
geckleopard
I updated the Bluray Player FW and also disabled my Wifi to ensure there was no interference and it worked smoothly then for video. Thanks for your support.
Ian
