mini pro sleep mode-switch off issue~!
i own sk17i from gujarat i have only one major issue which is at night when the phone goes in sleep mode for a longer span of inactivity even if its on and in sleep mode any caller from the other side finds my phone "switched off" but as soon as i activate  my phone when i wake up in the morning again it resumes normally.
this is very problematic in case of emergency if anyone tries to call me at night!!!
thanks for your help in advance!
Slightly_smiling_Face
26 REPLIES 26
did this issue recently started?
go to
settings -> call settings -> call blocking
press and hold the power button and take a screenshot
slimshaddy
Hero
have you checked it yourself :smileygrin:
i asume you did..
well this is new..
check again if it shows same behaviour or not..if it does..
change the sim card of a different mobile operator,,,,
insert the other sim card and see if the problem persists or not..
i have not yet updated to 2.3.4 ICS its still gingerbread so cant take the screenshot.
but as per your instruction i checked. each and every call barring options are DEACTIVATED/DISABLED.
i will update it to 2.3.4 today itself to chk if the problem is solved but i doubt it.
thanks... awaiting more suggestions.
2.3.4 it's not ICS, ICS = 4.0 Dizzy_Face
but yeah try the update and don't forget to backup beforehand
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
thanks will do the needful and get back to you!
install, if you haven't already,
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
don't forget to mark the Correct Answers Helpful Answers
i have already downloaded and installed USES 2.11.10.7 is that ok?
that's fine
