micro SD card
micro SD card
Hi!
I just got X10 with Android. Unlike the blackberry that I used to own I cannot access the microSD card from my linux machine. It detects it but does not open it for file transfers. I replaced the microSD card with the one I had in Blackberry and the phone accepetd it and was able to find all the media files on it. However the linux desktop (Fedora 12) still could not access it. Note this is the same SD card that I used in BB and all the files there were transferred using this linux machine before. Is it something in SE X10 that is blocking this.
Please comment!!
Thank you.
Asif
10 REPLIES 10
Okay for those of you following my earlier messages. There was nothing to this problem. I was just mounting the sd card in the settings area. Apparently, the first time you connect to PC you have to drop down the menu from the top which will show something like "Turn on USB Storage". Once you turn on it will not bother you again.
Thank you again for all the help.
Best Wishes!
