hello I have a sony xperia zr and I have problems with the mic when I am in a call the other person does not listen to me
but some times yes it is updated but still the same
thanks
I suppose you mean that the other person can't here you sometimes?
If you had you phone under water there might be some water block the mic. Try to blow on the mix to see if it gets better.
Also you could try to start your phone in safe mode to see if the problem might be caused by some 3rd party app you have installed in your phone.
