Hi, i can't receive txts from my Sony xperia LT30p. I can however send . what could be the problem?
Macha
Hello,
Have you tried sending a text message to your own number and check if it is coming through?
Check and change the network mode to GSM mode only.
Settings >> More >> Mobile networks >> Network Mode >> GSM Only.
And then do a Manual Network Selection.
Settings >> More >> Mobile networks >> Network Operators.
Phone will search for networks and show the list. Select any other network and it'll fail to register. Then choose your network from the list. Make sure, SEARCH MODE is set to MANUAL.
Note: If the person who is sending text message is an iPhone user, might be sending it as iMessage, so he/she need to turn the phone's iMessage to OFF prior to sending text message.
Thanks
