message alert issue
pankaj_101
message alert issue
message alert works fine in normal but after you connect headset make a call and then remove headset.if u recive a messege now alert is not heard ony vibration are there no message tone.
issue is still seen after latest update to build no 6.1.1.b.1.54
4 REPLIES 4
Siddz007
Actually i have not updated my XP to 6.1.B.1.54, i.e. still running the same old ICS FW 6.1.B.0.544 and facing the similar problem.
Sometimes, message alert tones are not active, (This includes Whatsapp Msg Alerts too),
I have to restart the cell for this issue to get resolved.
Another bug regarding Connecting - Disconnecting headset is:
When i listen to music, n try stop using button on headset, music playlist is paused,
Now if i remove the headset, the music starts playing on loudespeaker, which ideally should not happen.
Sony Should do something abt this too in their next release of FW,
Johan
I have noticed this and forwarded it for investigation. Unfortunately I do not have any work around at the moment.
pankaj_101
even now with JB i am observing the same issue...
more then 6 months and still isuue is not resoled :smileyangry::smileyalert:
Blazekick
It should be ok if you plug your earphone in and remove it again! i faced this issue once and i plugged my earphone and removed it again then it was working fine!
