mediaserver battery drain
tatter
hi all, has anyone got any ideas to get this mediaserver battery drain sorted.
Only had e3 1 month and had enough,
Yesterday 98% battery usage by madserver and phone getting hot. Have removed sd card, closed google updates/services, tried stopping every app. Can only get down to 70% usage.
  Should never have this problem with new phone. WHAT ARE SONY DOING TO GET THIS PROBLEM FIXED AS IT SEEMS TO BE A BIG ISSUE.
I had xperia z before with no probs, wish i hadnt bothered with sony again.
9 REPLIES 9
are you using spotify or auto updating your apps?
tatter
hi, no not using spotify or auto updating. Im trying to switch off everthing i can inc google sync and any google service at mo. it keeps trying to start google play app
profile.country.RO.title
_alexdon_
Try settings-apps-all-media storage,force stop and clear data. Restart. See how it is.
alexdon
tatter
hi, i did what you said about forcing stop, clearing data and restart. phone was fine for 24 hours with low mediaserver battery usage but
has now gone up to 98% battery usage by mediaserver and getting hot.
   Ive had enough of this phone as no one seems to be coming up with a permanent fix. Im spending most of my time trying to stop mediaserver and my battery runs out while at work. The phone is only a month old and shouldnt have these problems. What are sony doing about it?. I appreciate your help, but i should be able to use the phone when needed and not have to worry if i have enough battery and what mediaserver is doing. Thanks
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
tatter
thanks for help, ill give it a try over the weekend. if it doesn't work i think ill be returning it as cant carry on with spending this amount of time over a phone and getting annoyed. when people ask what phone it is i now say dont bother with it as too much trouble.
tatter
if i do a software repair on phone will this affect my warranty with vodafone as only a month old, thanks
it won't
PC Companion (PCC)
Bridge (for Mac)
_alexdon_
Keep us updated.
alexdon
