Media Go is freezing
Nyonge
I have Sandisk 16Gb class 10 on my Xperia M but when I connect (and automatic sync) the phone to PC with Media Go it takes time too long. Is it common take 2 hours just for sync 13 photos on my M? I try to press the eject button on Media Go but it just keep trying disconnect and doesn't work.
Does anyone has same problem with me? Someone get solution for me? Thanks
MiniMe
Yes it is normal. Now you have to ask yourself is that an acceptable amount of time or would you try an alternative program.
Every Xperia phone that I bought, I tried Media Go. Version 1.0, 1.5, 2.1 it doesn't matter, it creates about 10 different problems on my phone. Every time I thought it was me. I asked for help here and I messaged through Media Go to the developers. You will waste many, many, many hours trying to sync a large library using Media Go.
I have a 32GB SD  that is almost full and believe me I've had enough. I use iTunes and an Android app called iSyncr. It opens up a tiny program that syncs the iTunes folder directly to your phone. It works perfectly and quickly.
Good luck friend.
