Major issues_ Xperia c
rokin
I do have 3 major issues with this phone
1) if I charge the battery to 100% them it drains very quickly from 33 to13% but if charge it to some 80% it works properly, why and solution.
2) it does not remember anything about home screen customization on rebooting. Every single app(on sd card) which I had moved to home screen, on rebooting I would not find them, moreover I have installed some apps like Google drive, economics times, wordweb etc on sd card but after restarting it they were simply lost, I mean it's annoying you are losing all your important data just because your phone can't remember thing on your memory card.
3) I don't know why but some times it restarts on its own.
I use16gb class 10 memory card.
This is my second phone first one they(retailer shop)
Replaced thinking that above mentioned problems were piece specific but I am facing same issues on my second set also.
121 REPLIES 121
CP_Chong54
I just brought my Xperia C 10 days ago.
I found out that when the battery level reaches 35%, it will start drain at a rate of 1% per 15 seconds and stops at 13%
This happens every time when the battery level reaches 35%
I have tried reinstall firmware of the phone but the problem still persists.
Is there any other Xperia C owner also facing the same issue, is there any solution available?
I am very appreciate if someone can help.
Thanks in advance.
Take it back to the store or a Sony repair center
CP_Chong54
You don't say?
I came here to look for solution without having to send my phone to service center and you asked me to send my phone to service center.
Thanks for the quick reply anyway...
mustang2011
Don't be rude, maybe there is a problem with your set. Why do you always wait for 35%, why not recharge it at 50% ?
goyal94
xperia care solve these universal problems with xperia c , these occurs with all my xperia c phones replaced 4 times and still same issue in 5th xperia c phone . many others also facing same as i read reviews problems in xperia c -
1. Apps or Games in SD Card (any type) which having shortcut on home screen disappears after restart , but shortcut of apps or games which are in internal storage (phone memory) remains on home screen even after restart . also replace phone 4 times same issue .
2. Big Issue - Whenever Battery reaches to 35% or near this then it drains very fast in 2-3 minute it reduced by 20% until i switch off and switch on after 5 minute with all things off & with low battery mode , it stop then and work as usual . From 100% to 35% it is very nice as it drains very very low and drains 3% in 1 hour with average use . so it is very very big issue . also replace phone 4 times same issue .
3. Again with battery related - Sometimes when we do call while charging and after disconnecting it stops at 80% and after that it charges very very slow and charges 4% only in 1 hour which is very less than its normal time which is 32% in 1 hour . also replace phone 4 times same issue .
And please directly contact me with solution on my mail id with which i posted this issue and no service center and customer support could solve these however they tried many times but cant succeed , so solve these , your brand name does not suit these issues .
_Ashish9433
Even I am also facing the same battery issue as mentioned by goyal94, my battery drains approx in 5min from 30% to 5%. There is definitely some issue with the software in Xperia C. Also one more very irritating issue I am facing is when I call to some number, any number and I put the phone to ears, due to proximity sensory the screen goes off, which is a feature but after replacing it back from ears screen should again come live, but It doesn't. EVEN after pressing power button the screen flashes but didn't come up. Many times even when I am not on call it happens that I press the power button but screen does not gets on. It gets on after 30-50sec. 2-3 times I had issue that I cannot get to power on by pressing power button, I tried volume keys as well but screen doesn't come up. Then I plugged in the headphone still didn't come up. Finally when I called my self from friends phone my phone started working. I don't get this issue regularly but occasionally. Please fix it asap
jenitshah
Hi all,
        i am also facing this issue while my phone battery goes to 30% to 35% after 5 minutes it goes down to around 10%.this is very serious problem.
jenitshah
    i got the phone 20 days ago face the issue that my screen is shivering occasionally not regularly.and sometime it display totally blackout on screen.
Another issue i am facing is that my battery drain fastly from 35% to 10% within 5 minutes from 100% to 35% it goes nicely but then after it goes fast drain.
there is some other software related issue like on reboot the software icon on home screen disappeared.
i buy Sony for its quality product but i am very much disappointment with this phone as per its quality concern.
Please sony do the needful in this issue.
Johan
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to check how to proceed with getting this fixed.
