- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
M2 Aqua screen issues
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi YvonBianco,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
Don't forget to backup the handset using PC Companion, or you will lose your data.
Let us know how you get on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry but have to repost this issue because no one responded for the last week.
Usually when I would not use my phone for 30 minutes then unlock it, my screen would turn on and off again. When I press again the part l power button it would turn on and off again. And usually I have to press the camera button to unlock my phone and when I'm in the viewfinder of my phone, it would start to flicker and turn on and off until the screen turns black. And I have to lock my phone and press the camera button. It's a big nuisance because when I need to use my phone, I have to restart it in order for me to use it. Usualy the issue would happen randomly and sometimes, after I recovered the firmware, the issue still persists. Even after several reboot to the device, still the same issue. Here's the video to help me with the issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey, do u have the developer options unlocked? (they must be in SETTINGS)
if yes, scroll down to "Show surface updates" and uncheck the box. there might be other settings there that might need unchecking.
if no, go to abput phone, scroll down to "build number", and fast click on it several times. U must get a msg like this: congrats, u are now a developer. Then go back to settings, and "dev opt"s must be right before the" about phone" ....and continue with step 1.
I hope this helps
