m2 aqua lockt
cspoike
m2 aqua lockt
My phone is lockt some how and I don't now how to onlock it.
Tags (1)
2 REPLIES 2
profile.country.RO.title
_alexdon_
If the above doesn't help,you need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
