I did upgrade to lolipop but the phone is turned on and writes optimize applications and comes to some 70 265 and turned off the phone, and so on .Jel knows maybe someone what's the problem? Android 4.4.4 installed without problems.
phone lights up and writes optimize applications and if I istalirao clean install android 5.1.1
That's quite odd, you might want to contact your local Xperia Care
xperia no support in his country
Something is blocking the phone to raise android 5.1.1 but do not know what all I have tried without success I think some file real problem that remains, and if I put that erase all data from 4.4.4
Is there a program that can clear all arrears of files that were left, that the real problem? Obviously there is an error that does not allow Android to boot.
Firstable sorry if my english is uncorrect.
After i update the phone , the phone is optimized the apps , and this is the problem in this screen , already restart it self again and again , it never open , i can't use my phone , please help me.
Force stop the device:
http://support.sonymobile.com/global-en/xperiam2aqua/userguide/Resetting-your-device/
Turn it back on.
i tried this already , and when i push the power button again , " SONY XPERİA " AND " ANDROID POWER" AND optimized the apps screen and the same problem.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
I tried the PCC too , 1 hour later it was over and i tried again turn on my phone and the same problem again. I cant use my phone
