M2 apps optimizing and turns off
SSSS1
I did upgrade to lolipop but the phone is turned on and writes optimize applications and comes to some 70 265 and turned off the phone, and so on .Jel knows maybe someone what's the problem? Android 4.4.4 installed without problems.
22 REPLIES 22
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data unfortunately
SSSS1
tried and still the same
SSSS1
My phone will not accept the general lollipop signs lit up and started to lift the system, and then turns off and turns on again and again .Android 4.4.4 and 4.3 running without problems.
@SSSS1
Charge the phone for about an hour and then try again with PCC
PC Companion (PCC)
Bridge (for Mac)
SSSS1
I tried and still the same
@SSSS1
Remove the SIM and SD cards and try again
SSSS1
I tried the same thing happening. I think some residual file from a real problem 4.4.4. Did you have an idea how to solve?
@SSSS1
Have you unlocked the bootloader?
SSSS1
No not unlocked
