Loudspeaker/speakerphone will die if received a call while listening to music thru earphones :(
Adi
Hi Sony,
I have some weird problem with my Xperia U. If I receive a call while listening to music through earphone, phone will only vibrate. Nothing is heard through the earphone. After receiving the call, call timer display will come start after 4-5 seconds. Now, nothing is audible. I removed the earphone, then also loudspeaker both front and back is not working. After disconnecting the call, I played the music, but nothing is audible Slightly_frowning_Face I received a call without earphone plugged in, loudspeaker totally stopped working Slightly_frowning_Face Only way to set it right is to restart the phone!!!
Please let me know whether this is a software issue or hardware issue. If hardware issue, guide me to get a replacement. If software, fix it ASAP.
This should be fixed soon.
Please help!!!! Slightly_frowning_Face
Thanks,
Adi
58 REPLIES 58
Aimee
Enthusiast
I'm sorry to hear you are having problems Adi. I currently use the Xperia U and I don't experience any of these problems. Are you using the earphones which came with the handset or are they third party?
Have you tried repairing the software in the handset through PC Companion to see if this makes any difference?
What do you think about this forum? Let us know by doing this short survey
Adi
I am using the one received in thr box. Slightly_frowning_Face
Now I made a call and pressed on loudspeaker to activate it. All of a sudden I hear one sound like zrr.... rzrrrrrr.....zzrrrr.....like a drilling machine Slightly_frowning_Face
something is wrong Slightly_frowning_Face
I received a call while earphone plugged in. Thats it... loudspeaker is dead now Slightly_frowning_Face and some sound of drilling machine....
pls help Slightly_frowning_Face
If this is any sort of hardware issue, let me know immediately Slightly_frowning_Face and how should I get a replacement ?
Adi
I have not updated the software yet... I will try.. Slightly_frowning_Face
Aimee
Enthusiast
We wouldn't be able to confirm whether this is hardware or software at this stage. Try updating the software and see if that corrects the issue for you. If it does not correct the issue, I would suggest that you contact the store which sold you the handset.
Adi
Okay... I will update the software today... lets see... Slightly_frowning_Face
I'm facing the same problem since i've bought the phone! Whenever I'm listenng to music with my earplugs on and I recieve a call in between, then everything goes mute. If i recieve the call, then nothing is audible and it automatically gets disconnected in 4-5 secs. As rightly said by Adi, nothing works after that...like music and volume related things. Restarting the phone solves the issue.
I found only one solution to this is to take pre-caution abt it. I usually connect the earphone and dial any no. at the beginning before I play music. then whichever call i recieve, i'm able to answer it.
But it doesn't solve the main issue. Pls help me out from this.
Regards,
dhayanand
I too facing the same problem even after i updated the software! Thinking_Face
dashingguyof2k
could a mix match be an issue? as the earphones we get along has sony ericsson tag to it, and the phone is of "sony" and though behind the xperia u its having sony ericsson logo?!
though the earphones are only able work in xperia u, as i plugged them in my arc s and it said heaset not supported...
i don't know but it has speaker issue, now this issue... dunno what more! Slightly_frowning_Face
Adi
No luck Slightly_frowning_Face  I have updated my phone to recent available update ... but the problem is as it is Slightly_frowning_Face
Aimee, please guide what should I do? My phone is up to date. You can see the same problem is reported my many here Slightly_frowning_Face
If anyone got the replacement in Bangalore, India, please let me know whom should I approach.
