Yesterday i have updated my M2 with lollipop, After that i am facing couple of issues.
1) Huge battery drainage
2) Memory low issue ( first i have reset the device with wiping all the user data after that i have updated my device. It consumed lots of memory for OS, after installing 8-10 applications its started showing memory low msg)
3) Calling feature is complecated than before
4) Camera is not clicking pic with touch click
5) Walkman ( music ) most of the features is not available which is available in 4.4 ( headphone selection option is not good )
6) Most of the system application is not using full screen mode
7) Brightness issue ( i was able to see the screen properly at lowest level in 4.4 but not in 5.1 )
Hey guys , what do you think ? Should I update my Sony Xperia M2 from 4.4.4 to 5.1.1 ?
Yes/No
Please leave a comment and state the reason why should I or why I shouldnt .
Thanks
bro if update to lolipop will the iluminating bar will work or not
Here are some things you can try to help you with your problems:
1) Camera is worse than before and it will need to be fixed by a new update.
2) To solve this problem go to Stettings>Apps>All>Xperia Home and clear data and force close, this will reset the launcher to it's factory state but won't affect or delete any of your files.
3) I can't help you with this, except advise you not to use any third party task killers apart form the stock one.
4) Don't use third party cleaners to clear junk, the junk is in fact cached data. You should clear the cache of an app only if it misbehaves or is sluggish. Junk cleaners do more harm than good. Here is a good article that explains this:
http://www.androidcentral.com/android-201-how-and-when-clear-app-cache-or-data
Hope it helps,
Muchakis
I have Xperia M2 when i updated to Lollipop My mobile ring is at the max volume but it is very low
Any one has a solution for this problem
Thank alot
No, Sony still hasn't fixed the bugs.
The only information we have from the support team is that they think the new camera is an improvement, despite the majority of M2 users complaining about the issue.
They haven't said a single word about even trying to fix any of the other bugs, so I doubt they ever plan to release another update/fix for M2/M2 Aqua.
