Yesterday i have updated my M2 with lollipop, After that i am facing couple of issues.
1) Huge battery drainage
2) Memory low issue ( first i have reset the device with wiping all the user data after that i have updated my device. It consumed lots of memory for OS, after installing 8-10 applications its started showing memory low msg)
3) Calling feature is complecated than before
4) Camera is not clicking pic with touch click
5) Walkman ( music ) most of the features is not available which is available in 4.4 ( headphone selection option is not good )
6) Most of the system application is not using full screen mode
7) Brightness issue ( i was able to see the screen properly at lowest level in 4.4 but not in 5.1 )
Xloud is not removed, according to Sony support it is now included in Clear Audio+.
/t5/Xperia-Z1-Z1s/xloud-on-14-5-A-0-270/m-p/1042710#M45555
It is downloaded then you can install it at any time.
Just i have repaired / install my M2 using PC companion and here is the space related issue. Its a fresh OS, no app is installed.
On PC its showing 2.74 GB is free, On OS default storage app its showing 3.75 available and on filemanger its showing 1.2 used.
1 GB space is missing !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Agreed, but earlier with 4.4 it was same on device and on PC also.
I have one confusion. Space used by Lollipop OS in my phone is normal or what.....because earlier i have got low memory msg after installing 8 to 10 apps.
After updating to Lollipop and performing factory reset, the GPS is unable to get a fix in 10 minutes. M2 dual.
