Maybe there is an easy answer, but How to change or rearrange the "Lock Screen Quick Settings"?
you can arrange the Quick Settings icons in the notification area easily, and if you remove something from there it will be removed from the Lock Screen Quick Settings.
regards,
that's for rearrange when you swipe down from any screen not the lock screen.
Not sure about lock screen if you can change order but let's see what @Rickard has to say.
When i check my phone, the sorting of the lock screen quick settings is the same as the one i have when the phone is unlocked. However, not all quick settings are available on the lock screen (see http://talk.sonymobile.com/t5/Xperia-Z3-Compact/Notification-screen-shortcuts/m-p/975532) which makes the sorting look different as you don't have the same settings. Do you also see this?
yes @Rickard, it's the same sorting but not all the settings are available and it can't be edited for the lock screen only, and I think it should be edited, because maybe I need the airplane mode in the quick settings but not in the lock screen (if it's stolen for example), am I right?
Can I disable Quick Settings when the screen is locked?
I usually put the Z3 Compact in my pocket, but Quick Settings are often adjusted accidentially even when the screen is locked.
It is very annoying that some of my settings are adjusted unexpectedly, and WIFI hotspot or flashlight function are sometimes enabled accidentially.
Could you help to feedback this problem?
Thanks!
