hi sony people,
i use an xperiaZ and now have bought some charging devices with lithium akku for charging on tour.
but my sony xperia does not charge wuith these devices!?
all other phones (htc One X, LG Nexus 4) does charge but xperia not !!
can you help me to find out why ??
best regards
paul
Well, Xperia Z has a bigger battery then both of the two other models you mention. That might play a role. Unfortunately I don't really have any good ideas what to do here. Does the power source say it's compatible with Xperia Z?
Hi Samuel,
the power source does not say ANY compatibility, but it offers an simply USB Female Port for loading.
there is no compatibility problem because it is a 4 Pin conector which is normed to USB standard!
see here:
http://www.mipow.com/en/product/power-tube-simple-5200-for-micro-usb-devices.html
it gives maximum 2 A Power, should enough for ANY device, or not ??
Well, on the link you posted it actually mentions a few phones as compatible.
It should however work, but I don't really know what you can do here as there are no settings in the phone to control this. Does the phone charge normally via wall socket charger and USB?
