Liveview not pairing
My Liveview is not pairing to my Motorola Atrix. I have reset my liveview and atrix multiple times, but they still will not pair with eachother. Any ideas on how to make them pair?
7 REPLIES 7
Jonathan
Could you please advise me on whcih Android Version your phone is running on?
Can you also post the process you are using to pair both these items?
Thank you.
My phone is running Android 2.3. To connect the two, I just turned on my bluetooth, tapped LiveView to pair, and then used the LiveView application. It worked for a while, but after I pressed "Unpair" on my phone, it would not work again. Do you know how to make it pair again?
Jonathan
Are you using the same process as listed on page 12 of the following User Guide:
http://www-support-downloads.sonymobile.com/mn800/userguide_EN_MN800_1245-8216.2.pdf
I already tried all of those steps, but after I press "Confirm this passkey" it goes back to the blank watch screen (showing 0:00) and does not pair with my phone. When I click pair on my phone again, it comes up with a number that is not shown on the Liveview, and then it says "There was a problem pairing with this bluetooth device". Any idea on how to fully reset the Liveview?
Jonathan
Please view page 24 of the User Guide listed above, in my previous post.
I've already tried the reset, but it hasn't helped at all. Is there any way that I can do a factory reset by plugging it in a computer?
Jonathan
Yes, please use the following program:
