my connection become limited at some wifi network.
its become limited when i connect to restaurant wifi next to my office.
its perfectly work at another restaurant just a couple of block from there..
same thing goes when i go to public place like mall, some network perfectly connected the other got the limited connectivity issue.
im compare with my friend's phone connection at office, theirs working perfect.
it all depends on the range of your phone and the wi-fi device..
the restraunts u're talking bout, where u get strong conectivity, the wifi device is comparitively close to ur phone than the other at the othger restraunt..
how bout others gajet then? theirs working perfect.
my officemate can browse smoothly but mine got the limited notice.
:smileyplain::smileyplain:
maybe play's connectivity is not that strong..
go to nearby service centre and get it checked
or wait till SE reply
Go to Settings -> Wireless & Networks -> Wi-Fi Settings -> Press Menu -> Advanced
Press Use static IP to put a check in the box and then enter the network settings as per your own network (if you’re not sure what your settings are, (and assuming you’re using Windows) open a command prompt by clicking Start, then Run and typing in cmd and hitting enter and then typing the line ipconfig -all and hitting enter, the relevant details should be listed there. -Just make sure you use a different number for IP address on your phone than is shown on your PC!
hi uliwooly-wooly
im a novice when it comes to this stuff. when the command box comes up and you type ipconfig -all, and all that writing comes up, what am i meant to do with that information? under the use static ip address it asks for an ip address, gateway, netmask, dns 1 and dns 2. what am i meant to enter in there? and how do i know what ip i am meant to enter in the ip address box, where do i get that from?
this is driving me nuts. i have had the phone for months, and havn't had a problem with it. now all of a sudden it wont connect to my router at home when every other wireless device in the house does. there have been no new devices added since my phone. i havnt mesed around with any settings on my phone until this problem. i just dont understand why it has worked for so long and then all of a sudden it stops working! whats worse is my brother has the same phone and he hasn't had any issues! i hope you can help, or someone can help!
To avoid complication you could try to use the Wifistatic application from the Market as this performs a similar function without the complication. Basically you download it then open it whilst trying to connect to the router and it will offer the option to add a configuration for the router and may resolve the issue.
