I have had my handset for about a week now (pre-ordered on Sony store, received it on Oct. 7th), it's an orange D5803, production labeled as 14W37.
Last weekend, a few days after owning it, I spotted at first a brighter spot at the bottom of the screen. As I left on the original protecting plastic foil, at first I thought some air just got trapped underneath it. After removing the protection layer for applying a proper plastic protection, I figured it actually was a screen bright spot.
Investigating further this issue, I noticed than by touching at the bottom of the front glass, "color waves" typical of suffering LCD displays appear up to the spot all along a vertical line, which I figured being an internal reinforcement or otherwise part of the inner structure.
More details in the following pictures:
(original size at https://dl.dropboxusercontent.com/u/14131505/Z3C_brightdot/combo2.png)
As I tried to render with this "3D scan" of the front glass surface (both the phone and the light source were fixed, the point of view for the camera moving in order to perform a full swipe), the screen seems to be "pushed up" from the inside of the phone, just underneath the bright spot.
Normal view:
(original size at https://dl.dropboxusercontent.com/u/14131505/Z3C_brightdot/DSC_0082.jpg)
Detail of the bright dot area:
(original size at https://dl.dropboxusercontent.com/u/14131505/Z3C_brightdot/marker.png)
Emphasis on the detail (custom color tone curve) to show the affected area:
(original size at https://dl.dropboxusercontent.com/u/14131505/Z3C_brightdot/threshold_emph.png)
What happens on touching the bottom:
(original size at https://dl.dropboxusercontent.com/u/14131505/Z3C_brightdot/touch.png)
As I turned off the device, I had the opportunity to check a theory I had formulated in these days: the SIM tray appears to end up exactly underneath the bright spot, thus its supporting structure (faulty design tolerances/incorrect assembly?) may be involved in "pushing up" the screen from the inside.
The device turned on without the SIM card tray showed the same bright spot/"off-screen touch" behaviour, thus I'm afraid the LCD is damaged already.
I contacted support, which reported that it's not a known issue, suggesting to turn it in to assistance for technical verifications.
I have neither seen any similar case. I would suggest the same as your local support team did, visit nearest service center to have your phone examined by a technician.
Well, in good synthesis the answer is: yes, I had it fixed with the complete substitution of the device.
In fact, the actual story has gone on for a while: after the first repair - a substitution of the screen assembly - the waterproof grade was in doubt. I then had it sent to service again but this time, in addition to the positive result of the waterproofing test, the brighter spot had come back.
After calling the support service, quite upset, I was contacted directly from the service technician. After a brief chat, I returned the phone to service and they sent me back a new one. This time, it works like a charm.
welll,my father has bought the xperia t3 for me on my birthday ... then after the 2 days the same issue of the lighter spot on left at bottam ....which is glow ......i thought this is system of the glass on it but after removing this protect glass this is same as uper reviews........so .....it is not fare that ........the spot is come
well...... after meet service center ........they take my phone back to replace the new one.....with my phone box and all acceseries......and told in 2-3 days u have your new phone ...........:smileyhappy:
seriously this is not well now.............my mobile sony xperia t3 for replace ment .......there is 8-9 days are gone but up till now for this problem the mobile is not replased yet and not company give the new mobile .....2-3 days are now become 8-10 days it is too laziness of the company ........
please if read this company employ send my phone quickly.......xperia t3
